Fuel flow
Hello all, my engine just hit tbo. However my compression are all 77 or higher and no metal in the oil, but last night i noticed my fuel flow would at times drop to about 3 psi, then go back to 5.
To confirm its not the gauge, the electric pump holds 5 or more steady.
Is this a concern?
Thanks..
Kevin
Is this a concern?
Thanks..
Kevin
Anytime you've got only one engine, any anomaly is a concern. Your engine might be in perfect health, but I would definitely have your A&P look at the fuel pump. That probably needs attention.
Thanks Scott
