Please help!! my upper door latch broke
                    The upper door latch on my 1978 Cherokee 6 broke!  After closing the door and looking up to fasten the upper latch, I noticed that the latch handle was missing. I found it laying on the floor. The handle broke off at the neck or barrel that the handle screws into. (its a plastic barrel and it looks like it just cracked off. My question is how do I get a replacement and where?
Nick
                            Nick
63039-00 (sometimes this is listed as 63039-000) 'HANDLE - Door, auxillary'
I would be inclined to get a complete upper door latch assembly from a salvage yard such as Faeth Aircraft (Sacramento CA) or Air Salvage of Dallas (ASOD - based in Lancaster TX).
Make sure you check in your parts manual to verify what I am listing - I looked this up in parts manual 753-689, pages 1E9 - 1E11, item 14
BTW - this is a plastic handle with a square channel attached to the mechanism.
Andy
I don't have the parts manual for your particular aircraft. A Piper Dealer can look it up by model and serial number. The part is fairly inexpensive and not all that hard to fix.
Here's an example http://www.chaparralparts.com/servlet/the-933/63042-dsh-03-cam-door-latch/Detail
It may or may not be the right one for your particular aircraft. You need the right parts manual to look it up.
Changing it is not terribly difficult. The whole latch unit is taken out, and carefully disassembled, change out the cam and carefully put it back together. Re-install and adjust the door latch.
The top door latch on my Archer broke. Is this an airworthiness issue? I can't find anything in the regs (understandably) that address it directly but there is language that "hints" that if any system or part is not performing its intended function, that constitutes an airworthiness issue.
I was already in the air when I discovered it was broken (my passenger didn't realize when they moved the latch that they were supposed to feel the "snap" as the cam latch engaged. Even with one loop in the pattern, the gap at the top of the door was 3/16". There was a fair amount of turbulence so I wonder about the impact on the door and the airframe when with that top latch broken.
My A&P is looking at it today but is it legal to fly until parts arrive?
This happened to me last week! I was wondering about airworthiness as well and decided its better not to fly. I looked at purchasing the entire assemble (used) it was around $300 and they were old and beaten up. I purchased the OEM cam for around $118 through Aviationpartsinc.com in Fort Lauderdale. https://www.aviationpartsinc.com/product/63042-002-cam-door-latch/ not sure if this is the same model as yours but wasn't difficult to change out. Good Luck! I am not sure why they are made of plastic either.
I got lucky. My A&P texted me a short time ago to tell me it was fixed. I don't have the details but when i talk to him I'll post the solution in case others can benefit.
The local FSDO responded to my email this morning only to gather more contact information and said that someone else who me in touch I'll post the summary of that conversation, too.
My cherokee door latch failed as well. It the same assembly using the same plastic cam. When mine fails the handle goes past center and the door will not close tight. So far Ive replaced the cam and spring to no avail. Anybody have any ideas?
Did you ever have issues with the handle going past center and releasing the hook?
I have an upper door latch assembly that I purchased from Preferred Airparts a couple years ago. I was having issues with my latch and thought it needed replacement, but after removing and cleaning up it worked fine. I had trouble finding the latch and paid $400 for the assembly. If interested, I would sell for $200 plus shipping.
Ben
For everybody with door latch issues decades back on the twin Comanche I installed an upper door latch kit and I believe it was from webco. I have not checked to see if they're still available but they are identical to the Piper ones on Cherokees. Perhaps somebody could check and see if they're still being manufactured It was very good quality It really sealed up the twin Comanche upper door area. Carl
As of 1/09/2025 Webco lists their WDL1 door latch kit at $765.00 and an estimated install time of 8 to 12 hours [?!] in their online parts catalog "Cabin Door Misc." This is for the Comanche, but see Carl's comment above.
Thanks Mike yeah if I remember right it was not a big deal to install it on a twin Comanche door with that did not have it It was pretty straightforward. I pretty much remember it was identical to the standard Piper latch. I don't see why it probably would not work on a standard Cherokee. Good to know at least they're still available. Carl
