Bike rack in lieu of back seats?
So I'm trying to figure out the best way to carry a couple of bikes in my '73 Challenger (with the 5" stretched fuselage). A friend asked, "Can you take out the back seats? What about putting in a couple of fork mounts behind the front seats?"
I haven't pulled out the tape measure yet; maybe when I do, I'll realize this is a non-starter. At first glance, though, it seems like there might be some merit to the idea.
Has anyone else tried this? Am I missing something obvious about why this would be a horrible idea?
My thought was that if the dimensions work out properly, I might be able to just drill mounting holes for the fork mounts in a spot that would be hidden when the seats are installed (if the stars line up, maybe the fork mounts could even remain in place when the seats are installed, but that's probably too much to hope for). Existing baggage straps might work to keep rear of frame securely anchored...
I participated in my annual in an effort to get to know my plane better, including removing the interior, so I'm familiar with how that part of the plane is laid out. If I go this route, I'll ensure there's clearance between any protrusions and the control mechanisms, and take measures to ensure the bike mounting hardware stays firmly in place so I don't end up with nuts rattling around among the pulleys and such.
> You will want to have some adjustability on your forkmounts(a little left/right forward/backward etc.)
Many thanks for your response. I had not considered leaving flexibility in the forkmount placement, but that makes good sense. Nice to hear from someone who's implemented that idea with good results! Gives me some confidence to move forward on it, if the dimensions for my plane and bikes check out.
To be legal, all you need to have is a W&B that up to date with the seats removed.
PilotKris
