0540 B4B5 acceptable cylinder head Temp
Hi All,
Seems that my 235 runs a little on the warm side and has for quite some time. The engine runs great, excellent compressions, good oil temp and oil pressure. Does anyone else have the same experience with the 0540 and if so what are your CHT's and what is an acceptable temp?
Thanks,
Thanks,
I usually Cruise around 22 to 23 squared between 6500 and 9500 and see CHT's anywhere from 375 to 390. I lean until the engine runs rough and than advance to where the engine runs smoothly and than advance just a touch more and I see around 13 to 13.5 gph on my JPI 450.
Make sure your timing is correct. Advanced timing will raise temps. Ask PK.
It must have worked as the O-540-B4B5 in the 235 has a reputation of not only easily making it to TBO, but exceeding it by 30-50% without problems, even without the "help" of multi-probe graphic engine monitors.
In short, it pretty much doesn't matter how ham-fisted the operator is, it's unlikely, short of some mechanical problem, to hurt that engine.
390 in cruise isn't especially hot and I doubt that you'll have any longevity issues because of it. Check your baffles and go aviate. Any issues you have will most likely come as a result of lack of use (1150hrs in 39 years).
PilotKris
It is hot here in Florida right now! Since you pointed my temp problem to timing, I have had no troubles at all with my IO360CIC. In an extended climb with it 100 out, I might see 360 on the hottest. In cruise, 2 and 4 go for about 270ish and 1 and 2 are about 300. I have over 70 hours on it since the issue...
Although now, your temps seam almost too low (especially in FL). Perhaps you're not leaning aggressive enough?...
PilotKris
