Washington SFRA
                    I'll be embarking on a trip which takes me near the Washington SFRA.  I'm going up to Albany NY from Fayetteville NC in my Saratoga HP.  I plan to fly from the RIchmond to the Patuxent and then MXE VOR's Just skirting the SFRA. I'm not sure whether I'm going to file VFR or IFR. I'm still not completely comfortable with my newly acquired IFR rating so I'm leaning toward filing VFR. (got it last September and I am current) I haven't flown in this area since before 9/11/ What can I expect?
Thanks in advace. Mike
File and fly IFR. Get used to it. They are obligated to be your partner then... VFR they can toss you any time they are busy and leave you to fend for yourself. IFR they are obligated to give you separation services... a comfy thought indeed.
I file and fly IFR all the time and admittedly, most of the actual flying is in clear air.
++file direct and take what you get
++file for what you think they will allow you to keep
I find if you file with what appears to be a thoughtful plan, they will often let you fly it. Go as direct as possible, but file waypoints around DC (for example). They will probably let you keep it "as filed". That allows you to not have the "amendment to flight plan, advise ready to copy" crap that we all like so much.
Also, go higher. Many restricted areas and such are only hot to 2999 or 4999, so at say 8 - 12K you will not be routed around them. I tend to fly 10 - 12K. Gets you over most weather excepting convection... but is high enough to see buildups in isolated or scattered t' storms and they will always allow deviations around that kind of stuff. You can lean like crazy and on longer legs is most certainly worth the climb for the better fuel economy up there. Plus, in the Summer... it is always cool up there too! You might even find an interesting sunset between layers
Fly IFR and use V16 to go east of DC. File for 7,000 or above and you'll be over R4007 that tops out at 5,000. Be aware, there's restricted airspace just to the east that goes up to FL250. There are preferred routes and TEC routes available as well.
I fly VFR here all the time but between the SFRA, Class B, and restricted airspace it could get hairy should weather force deviations to a VFR route. IFR is the way to go near DC.
