Been doing a lot of low level slow flying lately about 3,000 MSL
Question,
I been looking at stuff in the Arizona desert with friends and been flying about 1,000 AGL or 3,000 MSL
I know procedure is when climbing, run full rich until 5,000 MSL then lean out.
While I'm cruising around, should I be full rich, or is it ok to be somewhat lean?
1976 Arrow
1976 Arrow
"Some pilots believe that the mixture should never be leaned below 5,000 feet MSL, but this is not necessarily true. Most fuel metering devices are set on the rich side, which means that prudent leaning is permitted-in fact advisable-at almost any altitude when the engine is operated at less than 75% of its rated power. When a 5,000-foot restriction on leaning is recommended by the manufacturer, it usually is applicable during climbs when climb power is being used."
From the Pilot's Handbook of Aeronautical Knowledge, FAA-H8083-25A
"Regardless of the actual altitude at which the aircraft is operating, it will perform as though it were operating at an altitude equal to the existing density altitude."
With respect to JimC, I, the FAA and Piper recommend leaning in the high density altitude of Arizona so long as your temperatures remain in check. I've flow 6 different Arrows of various vintages. Despite student techniques, none have shown a tendency to get hot. They are basically trainers and are designed to take a degree of abuse from the pilot.
We're actually flying close to the border checking stuff out.
I did not get the chance to play the low and slow heat game today. Maybe next weekend.
Jim,
Please explain. It sounds like your saying that at anything over 100F, it will be impossible to cool the engine.
It seems to me, flying at a speed close to Vy (which is very close to best L/D) would requite the least amount of power per knot of IAS resulting in the greatest engine cooling per BTU consumed and therefore, the lowest CHTs possible.
In level flight, I don't see how slowing down (unless you're "behind the power curve") is going to make your engine overheat...
PilotKris
