Does anyone have a picture of a FF transducer installed in their plane
                    Can someone please post a picture of their or any plane with a fuel flow transducer installed with the plumbing.
I have a 200hp fuel injected Arrow and from what I understand the transducer gets installed between the engine driven pump and the fuel servo.
my connection is only a few inches apart and it was recommended to make a loop (roughly 2ft) in the line. I just want to see if anyone has some pictures to give me an idea of what it should look like.
Have you contacted EI to see if they had any photographs?
I don't have a picture, but the two foot loop is what I did. I had two hoses made up...the first is installed just past the fuel pump, and goes aft thru the baffling. The transducer is next, followed by the second hose that goes back thru the baffling, and connects to the servo. The total distance may be just more than two feet, but the transducer is not sitting right above the engine.
Hope this helps,
Keith
