Wheel pants and valve stems
                    My '73 180 came with a pair of beat-up main gear pants (stock) and no nose pant.  I've been (very slowly) doing some fiberglass and Bondo repair to the pants, so I've been flying without them on the plane for the short time I've owned it.
The tires need a shot of air about every 7-10 days or so (they drop below 20psi in about 10-14 days). With the pants off, it's (fairly) easy to get down there and get a pump on the valve stem. However, looking at some other planes around the field, it's not clear to me that I'll be able to access the valve stems once the pants are installed.
Is it feasible to air up the tires with the stock wheel pants installed, or do you typically have to remove them? And should I expect a tire inflation to last longer than a couple weeks?
Thanks,
Jim
Thanks,
Jim
I, too, find that I have to top off my 180C's tires every 7 to 10 days. Maybe I'll try new tubes also.
jrccea at gmail.com
and I'll send you a couple of photos. Basically, my doors are somewhat ovoid in shape, and when I push the button on the hartwell latch they drop off into my hand.
