"Hot Zone"
                    While looking at an approach plate for an airport I might use (MKL), I came across an area encompassing the end of a taxiway to a long runway that was boxed in by a rectangle with the label of "hot zone."  I have seen "hot spot" depicted on other charts, but not "hot zone."  Anyone familiar with this term?  Is it the same as "hot spot?"  I could not find any reference to this term on the FAA web site.
Thanks!
                            Thanks!
This discussion has been closed.
Guest
So you posted twice that the Hot-Zone others have stated what they believe they are, why don't you just post your answer for others?
So my question to the one Guest who says he/she knows the definition hot zone  How about giving the rest of us uninformed a clue as to where to look?
Scott B, CFI-I
Actually, sir, the OP didn't ask for the meaning of "Hot Spot", he asked for the meaning of "Hot Zone". That's Zulu Oscar November Echo, with nary a Sierra in sight. Let me quote from the original post, which perhaps you failed to actually read:
Personally, I believe that you have been strutting around, berating people for speculation and ignorance, and claiming that you "know the answer", when in fact you failed to even understand the question! The OP said he's seen "Hot Spots" before.
As for looking it up, all of the FAR/AIM and other publications are available via http://www.faa.gov, and they're all well-indexed by Google. An even more extensive collection of government documents is electronically accessible via the Gov't Printing Office website. However, neither the Google searches < "hot zone" site:faa.gov > nor < "hot zone" site:http://ecfr.gpoaccess.gov > yield anything that seems to answer the OP's question. Smart folks at the AOPA couldn't help, and apparently even the tower at MKL couldn't or wouldn't give a concrete answer to the question., so it seems your comment that "It's not that hard" is unwarranted. (Note that doing similar searches for "Hot Spot" instead of "Hot Zone" yield all kinds of information about airport trouble spots.)
I have done the latter; now I do the former: Do you know what a "Hot Zone" is (not a "Hot Spot")? Would you please share your FAA or other US Gov't reference that will clarify this point for the rest of us who would like to understand?
If not, then cease posting, unless it's to apologize for your poor behavior.
I'm starting to trend toward the "Guest feature needs to go camp" though I think that'd be a real shame.
At the risk of being skewered for an OWT, back in the day we had "Hot Spots" at USN airfields where live ordnance was armed on the way out and made safe on the way back. This terminology was standard at USN & USAF fields I operated from. Since KMKL has an Army Nat'l Guard Aviation activity, perhaps that means helicopters and they need a "Zone" instead of a "Spot" if they're either going to arm ordnance on a bunch of aircraft or load ammunition & what not onto a bunch of transports.
Or, perhaps, this is where all the Roswell alien stuff is kept...
If you go there and it's ever relevant, I'm sure the tower/ground controller'll let you know.
I'm pretty certain the PK/wannabe doesn't know jack on this one.
BTW, the airport manager never e-mailed back. I'm sure he/she hopes I'll go away, which I will.
