Cherokee 180 Nose Cowl
                    My nose cowl is cracked quite a bit on the surface, it appears oil is leaching thru the cracks.  When we started looking at it closely, there was a lot of bondo on the bottom side.  As we started sanding down the bondo, we also started having oil leaching thru the underside of the cowl also.  We are trying to come up with something to try to get the oil out of the fiberglass as we are rebuilding the cowl.  I was thinking about grinding up oil sorb into more of a powder and see what happens overnight, If successful, then do it again.  Any suggestions.
