What Would You Recommend to Upgrade a Basic IFR Aircraft?
                    I hope to start in earnest on my instrument rating soon, and I will be flying a very basic IFR Cherokee 180C: VOR, glideslope, dual KX-175B radios, heated pitot tube, inoperative ADF. I also have an AnywhereMap Quadra portable GPS. If you were inclined to upgrade this package, where would you spend your dollars first in order to get the biggest bang for the buck? Some ideas:
1. DME.
2. Better digital radios.
3. Sporty's handheld radio with glideslope.
4. Vacuum warning.
5. Garmin 430W.
6. Backup vacuum.
7. Electric attitude indicator.
8. ADF repair.
9. Autopilot.
10. Other.
                            1. DME.
4. Vacuum warning.
5. Garmin 430W.
6. Backup vacuum.
8. ADF repair.
9. Autopilot.
10. Other.
Get a 430. I have a 530 WAAS and it is wonderful. You will get a good portion of any investment in a 430/530 back if you sell... not true of most other stuff at this time.
Ditch the ADF. Put in an autopilot if you intend to do any real IMC flying. I have an electric Castleberry AI for back up if my vacuum goes down. Can't buy life...
For those of you who have Garmin 430s or 530s: how confident are you that the technology will be supported L...O...N...G term? If I'm going to shell out that kind of money, I need to know that I'll still be using the equipment years down the road. Is there any real competition out there, and, if so, will it bring prices down at all?
If you're talking "How long will Garmin continue to sell and support the 400/500 line of panel GPS units?" the answer is less clear. The venerable 430 was introduced in 1997...that's about a million years ago in terms of consumer electronics, but of course advances in the GA world come glacially slowly. Considering the extensive installed base of 400/500-series GPS units, I would expect Garmin will continue to support them for quite some time to come, but that doesn't mean there won't be a box coming out next year that makes the 430 look like...well, a 15-year-old piece of electronics (i.e., a dinosaur).
For what it's worth (probably not much!), it seems to me that ADS-B is "the next big thing" that might drive a new generation of avionics to market. I'm no ADS-B expert, but if my limited understanding is correct, the WAAS-enabled 430W is capable of providing ADS-B-compliant position info to an ADS-B transponder. If that's correct, then I think if you got a 430W today, it would not become obsolete when ADS-B requirements became mandatory.
Functionally, I think the 430W has the chops to carry it along indefinitely. Devices are WAAS-capable or they aren't...the 430W is. Devices can send/receive data over standard interfaces to other high-tech devices in the cockpit, or they can't...the 430W supports the important standard avionics interfaces. Garmin has demonstrated support for the product via hardware (WAAS) and software (multiple versions) upgrades over the years, and there's a large base of installed units in the field, so there's reason to be optimistic that they'll continue to support it for some time to come.
Newer boxes may (or may not!) appear on the market that are prettier, easier to use, or have niftier features. But that won't make the 430W any less useful. I don't think it'll go obsolete like your LORAN box in the foreseeable future.
