Quick question I have about winds
                    True or False: When strong winds are perpendicular to a mountain range, you can expect mountain waves? I have been told false but my research states it is true.
Tom
                            Tom
From "Gleim Private Pilot Course" Section 7.6 "Expect mountain wave turbulence when the air is stable and winds of 40 kts. or greater blow across a mountain or ridge".
The "King Private Pilot Course" video also illustrates the same thing. Hope this helps.
Not good to have the escape out of the capability of whatever you are flying in...
Wikipedia: Lee Wave
Wikipedia: Lee Wave
[Sorry about the duplicate post. Can't figure out how to delete.]
When strong winds are nearly perpendicular to a mountain range, you can expect mountain waves, correct? Well not necessarily.
Mountain waves require a very specific atmospheric structure before waves become apparent. Reasonably strong and nearly perpendicular winds along the ridge line are just one ingredient.
Mountain waves can only exist when there's unstable air below the ridgeline capped by stable air above the ridge line. As the buoyant and unstable air is forced up the ridge into the stable layer on the windward side, it will be forced downward on the lee side of the mountain ridge.
The air descends back into the unstable layer below the ridgeline and once again becomes buoyant and begins to rise back into the stable layer. This oscillation produces the mountain wave activity.
If you see a lot of cumulus cloud activity along the mountain range, this implies the atmosphere is unstable above the ridgeline. This environment doesn't support mountain wave activity.
