Long cross country advice
                    I am planning a cross country in my 235 from my home airport in Salisbury, NC (KRUQ) to San Diego next month for a conference. I have planned the route (about 2000nm, 15 hours flight time) to go basically due west until Texas and then a more southerly route to avoid the higher elevations. My concern is a narrow track near Phoenix where I will be a bit blocked in between the Mexican border and restricted airspace. Being a VFR flight my concern is weather and the fact I will have little or no room to go around weather and would be forced to just turn around. Anyone ever made the trip through that southern route to CA have any advice?
you can go to El Paso, straight to Tucson, then straight to Gila Bend VOR or airport. That puts you south of Phoenix and away from the MOA's and restricted airspace on your left. Then you go to Yuma VOR, then straight to San Diego with your highest elevation being about 5,500 on the last part and from El Paso to Tucson just 2 spots where elevation is almost 8,000
While VFR flight through active MOA's is permitted, I do not fly through them without coordination. As a former Navy flyer, I'm happy to steer clear of the area if it's hot. In general, if the weather is skosh, the MOA's are often cold since a lot of the activity they typically support requires pretty good weather over the area.
I have made four round trips to TX and only had one leg where weather forced me to stop short of my destination. A solid line of convection stopped me cold in Smyrna, TN. Great FBO, by the way. Spent the night watching NCAA semi-finals and got home the next day.
Good luck with the trip - I'd like to hear how it went.
I am not certain of your intended routing, but if you go the El Paso route, I would suggest that you include Newman on your flight planning it is an intersection and will keep you out of the MOA just to the North. ABQ Center will want that. Ryan Field at Tucson is a good stop for fuel and food. When you go NW from there you can avoid PHX completely. Find Vicko intersection West of Buckley, turn West toward BLH and then to PSP. By this time you will be talking to Los Angeles Center. I have flown through the pass at Banning at 8500 at night and it is quite pretty (and over the mountains at 11000 in the soup). Beaware that there is a tendency for low clouds to form in the Morongo Valley West of PSP and then again when you get to the Inland Empire (approaching Riverside/March ARB) but you can generally get below with plenty of altitude and stay VFR. You will be talking to SoCal by this time and then go to your intended landing.
If you go through PHX then you have the Class B and numerous airports plus Luke AFB to negotiate.
The southerly route puts you parallel to the Mexican border but that is not a particular problem. I have flown this both IFR and flight following with ease. There is a tethered surveillance balloon near Deming, its charted, but I have yet to see it (it's listed at 15000 feet and avoid that airspace.
It can be a challenging flight especially when the winds pick up in the mtns, but it is fun and worth doing, good luck and have a safe wonderful flight.
Larry
