cherokee tach reading low
                    Just got my AP to use an optical tach on my cherokee 140. He found the aircraft tach 100rpm low at 1000rpm and 150rpm low at 2000rpm.   Is it possible to adjust the aircraft mechanical tach?  New mechanical tachs cost about $450. Are the new digital tachs better?   Now I know why I seemed to have low static RPM. I'm glad the engine is ok and it was only the tach...phew.
What you're experiencing is the normal life cycle of the mechanical tach. The spring inside them seems to weaken with use - as they age they all tend to read low. A digital tach would not have this problem. Digital electronics just stare blankly at you when they fail. IMO which one is "better" depends on your faith in electronics.
>MikeL<
I agree completely with Mike as I have a digital tach that came with the plane when purchased and tough to read at time as it bounces around when you change the throttle for a second or two, the mechanical ones are a lot better I think.
