6 or 8-PLY Tire for '76 Lance (PA-32R-300)?
                    I'm confused! It's time to replace my main tires (and front). Will get Michelin Air again but the 8-PLY seem out of stock at Chief in OR. My parts-book says 6 PLY but doesn't really distinguish between a Cherokee Six and a Lance (or I can't figure it out). The Michelin website says 8-PLY for the mains. The load rating is 1750lbs for 6-PLY and 2350lbs for 8PLY. My plane weighs 3600lbs at gross. So I always thought 1750lbs per side didn't seem enough (I know there's some weight on the front, too) Any ideas?
And it gets even more confusing on the front. Parts book says 5.00-5-6 which seems right from what I remember and the tire is smaller. Michelin site says 6.00-6-4 which seems wrong. They have the Saratoga with a smaller tire than the Lance? Makes no sense. Aircraft suppliers says another... It's been so long that I bought tires and I'm not near my airplane to check what I have on there right now but need to order for my annual.
Tx for any input. Horstair.
In general you do not want to add plies to the tires on a retractable aircraft as the fatter tires may not fit in the wheel wells. However, if you've been flying around with 8-plies, you've proven it doesn't matter. But from the tone of your question I gather you're not sure what you're flying around with. So stick with 6-plies.
