Airspeed Indication Low
Just purchased a 1976 PA28-151 Warrior with the 160 RAM upgrade. When cruising level at about 2300-2400 RPM I am only getting 90-95 ktas indicated. Any thoughts on this? I have fatpants wheel pants installed also so I am figuring this is fairly low.
You don't mention many things that may be relevant.
Cruising altitude, airfield elevation along with Static RPM results, when was the tacho last checked with an optical or similar variety all come to mind for starters.
What does the groundspeed come back as ?
What airspeed would a Warrior normally be expected to achieve in your configuration ?
I would be confirming a few indication items before getting too concerned about airframe drag and rigging myself.
You may need to look at the STC sheets for your RAM upgrade to see your static rpm limits. The TCDS may not be applicable in your case.
