Stec 40 A/P issue
I recently purchased a 79 Archer and am still working through learning the airplane. This plane has an Stec 40 and this is my first experience with an A/P. It seems that the wing leveler and heading modes work fine. However, when I try to get it to track a VOR it will drift off to the left of the needle. Since this is new, to me, does anyone have a suggestion as to what may be the problem? An adjustment or a serious issue?
How is the aircraft set-up? What nav-coms do you have and is there a switch for nav-1, nav 2?
The VOR needle is centered when you activate tracking? Once activated, if you turn the obs knob and move the needle manually, does the autopilot chase the needle? Let's start there?
Bob Hart APG Eastern Avionics rhart@avionix.com Visit our Website? www.avionix.com
Thanks for the response. I have two KX170Bs and a GX55 that replaced a LORAN long before I got the plane. There's a rotary switch to select between the three nav inputs. It's labled NAV1, NAV2 and LORAN. I'm not sure if the LORAN position connects the GPS or not. I'll leave that for another time. I tried to do some nav testing on the ground, but the only nav signal that I can get is the localizer and that's not proving to be too helpful (full left deflection in the hangar). I'll try to fly it again this weekend and test using some VORs.
When I tried the heading bug on the ground, it seemed that the long term trend was to go into a turn one way or another. I figured this would be the expected behavior. I'm guessing that they've implemented the roll servo loop as a PID controller of some sort and the constant, uncorrectable error input, however small, from being on the ground would cause the integrator portion to wind up one direction or the other resulting in a roll command.
Raymond Balister
Send me an email directly so I can send you back some info? rhart@avionix.com Thanks! Bob Hart APG Eastern Avionics
