Archer III Oil Change
Is there enough clearance to use a standard size torque wrench to remove the oil filter on a 1998 Archer III?
  • Why would you want to REMOVE a filter with a torque wrench? I use a standard 6-point socket on a ½" drive ratchet wrench.
  • Sorry, I meant to install and tighten the oil filter.
  • BD:
    Easily enough room for either a click-torque or a bar torque wrench. Most filters have the torque specification printed on the side.
    Since you will be safety wiring the filter, bend the tabs at the base of the hex fitting up slightly to allow easy insertion of the safety wire before you position and hand tighten the filter.
