Low oil pressure
Fighting an intermittent oil pressure problem on my 1978 turbo arrow 3. Oil pressure spikes normally on start up and within 5 minutes slowly moves into the yellow range. Most recently it happened in flight. I normally sit at 50 PSI in cruise. Yesterday it was at 35 PSI. After landing at idle power I could barely keep it above redline. Seemed like a classic oil pressure relief valve issue. But I had that changed and 3 flights later it has happened again. Have also checked filter and screens.
it is not a sensor or sending unit as we hooked a analog gauge up and it matched.
all other indications normal.
any suggestions/thoughts ? Thanks
  • See reply in maintenance section
