gear in-transit light
PA28R-180, When I select gear down the gear in transit(git) light illuminates until I have three in the green. Then the git light turns off. When I select gear up the three in the green turn off and the gear in transit light remains illuminated. I have the aircraft on jacks and can hear the gear pump turn off. Visual inspection shows the gear is up. Pulling the gear breaker does not turn the git light off.
While flying I encountered this problem and pullet the breaker to protect the pump. Aircraft handled as if gear was up, no way to know for sure. Reset the breaker and selected gear down at destination. Gear operated normally and lights operated correctly
Does any one know what controls the git light?
http://www.eflightmanuals.com/ITEM_EFM/CAT_EFM.asp?cID=3144 or http://www.esscoaircraft.com/c-12691-piper-pa-28r-201-201t-arrow-iii-turbo-arrow-iii.aspx
The manual is outstanding for solving all kinds of problems and answering all kinds of questions. I recommend it highly. This should solve your problem.
Thanks for the help to correct this nagging problem.
