Oil cooler inlet plug
I wonder if anyone knows where to buy or how to fabricate a plug for the oil cooler inlet on my Arrow II? If I park for a few nights outside, it would be nice to know no critters can get in.
I made this out of scrap aluminum. Is this what you're looking for?
What you're looking for is an air cooler winterization plate and your aircraft should have come with one. There is a part number in your manual and you can purchase one for about $50. However, you can also make one for basically free.
I'm looking for something to cover the inlet "scoop" on the lower right side of the cowl for oil cooling. I'm thinking it would be a good place for birds to come in if parked outside for a few days. Maybe this isn't a problem. It should be waterproof.
Hi, do you mean like this? https://www.sportys.com/pilotshop/cowl-plugs.html
Scott,
He may mean the oil cooler inlet duct which looks like an NACA inlet on the lower cowl, right hand side. My '69 Arrow has one also.
Oh! Got it, much thanks Jim. So how about shoving a piece of foam rubber in there. And put this on the foam rubber plug. https://www.sportys.com/pilotshop/remove-before-flight-streamer.html
Simple enough. That should work. I'll probably just tie it to the cowl plugs so they will all come off at the same time at preflight. Thanks
Glad to help! Sometimes it's the simplest of solutions, lol.
Wow, you're talented! Great job!
@Casey, great plugs! What materials did you use (foam and what kind of fabric)?
Thanks!
Wow, beautiful work!
They're very inexpensive, weigh nothing, and if they get lost, it only takes about 10 min to make a new set. They're nowhere near as nice as Casey's, but they work great.
They look great. I think you should draw eyeballs on them, lol.
I like that idea. I better not paint them after this week because the eyeballs will turn out bloodshot. 🤣🤣
On my Arrow IV the cowl plug for the small 4"-diameter oil cooler air intake had gotten lost.
I asked several companies for quotes and they all ended up in the $80 range (incl S&H) which I found a bit expensive.
Hence I made one myself. The material (the faux leather and the foam) was about $6, and I spent about 45 mins with cutting and sewing.
