Winter flying
                    I was just curious - Living "up nort", the lousy white stuff will be arriving soon, and was just wondering how much peoples flying is reduced by the cold weather?  Do you find the plane is just sitting, waiting for warmer weather or is it still pretty easy to get out and fly?  I know that myself, being the warm-blooded type, I have to force myself to get out in the winter (except for deer hunting, of course).  I'm hoping that when the weather is nice, getting up in the air will be sufficient motivation to head to the airport, in spite of the snow.  I've still got about 6 years before AZ becomes a wintertime option!
It probably goes without saying, but make sure you have a CO detector in the cabin. Important year round, but particularly so when you're using your heater.
Happy (winter) flying!
Grand Haven! I used to be based at South Haven. Small world.
I generally don't disagree with Don's advice but on this one I've always heard the exact opposite. When I was first taking lessons, my CFI would hand rotate the prop a few turns on cooler days to "get the oil circulating." But when I became an owner and researched this some, most of the advice I saw from folks was that this can actually do more damage than good, because when all you're doing is turning the prop you're just scraping off what little oil is left on the parts without adding any more to it, since the oil pump isn't really active. So that when you DO finally start it up you've actually created a greater potential for metal-on-metal abrasion.
Can anyone point to a definitive procedure that's been recommended or approved by the engine manufacturer? I had the manual for my old O-320 but sold it with the Warrior, and haven't bought the one for my IO-360.
0320 start
Let's switch gears a bit although on the same theme. I'm in Atlanta so temps seldom get below freezing. And unfortunately I do have to keep my plane outside because of a dearth of nearby hangar space. However, the plane I bought came with a nicely operating Tanis heater system installed, which requires 120v power. Has anyone come up with an easy-to-implement, economical approach to portable power that I could use on those few sub-freezing mornings when pre-heating would be prudent?
I realize I'm coming to this conversation a little late, but thought I would let you know that I emailed Lycoming several months ago about whether they recommend turning the prop over by hand before cold starting. Their answer was no. I'll try to find that email and paste the text into a post. Their Key Reprints section on Cold-weather Operations (see page 48) contains a number of helpful tips, but it does not mention turning the prop over prior to a cold start.
Thanks all. I've looked at both power inverters and generators, and either of those do seem the only option. The power inverter I would need only costs about $50, but then I'd be leaving my car engine on for the 1-3 hours necessary to get the temps up. Generators allow me to walk away for awhile, but I hadn't seen any for less than $500 or so. I'll check at Wal-Mart, though...didn't think about that as a source.
